Cross posted to TBN, so if you also post over there, feel free to only answer in one location.
So here's the scenario- MF35 Utility, continental z134
I was using the flail mower to cut down some tall grass, cut some paths through my field. Was running the machine for maybe 1.5-2hrs. Temp gauge never moved, oil pressure good, radiator full, and clear of debris, oil is full.
I noticed it was starting to feel low on power, like when I'd get into tall grass it would bog down and the governor wouldn't pull the RPM back up. I disengaged the flail and was just going to bring it back up to the house. As I'm moving up a small grade in 3rd low, it started to bog even for that. I shut it off immediately at that location out in my field. The machine sat there overnight. I went out the next morning to fire it up, it turned a tiny bit and just stopped. The starter still works fine, but when it engages the flywheel it binds up tight.
Here's the information to know:
- it's not the starter
- I can normally spin this motor (z134) by hand off the fan when in neutral. I cannot.
- I tried to spin it over by the crank pulley. I cannot
- I tried to bar it over off the flywheel. It's stuck, It won't move.
- I tried a huge adjustable wrench off the PTO shaft on the flail with the PTO engaged, it will not move.
- The plugs look great, it was running beautifully prior to this
- No oil or coolant in the cylinders
- I can't see anything concerning in the cylinders with an inspection camera, but the camera I'm using isn't that great.
- I removed the front mounted hydraulic pump (MF35 Utility with a loader on it), the pump spins freely
Is my next step to pull the head? Any other suggestions before I go that route? It *could* use a valve job, so I'm not opposed to pulling the head. I already have the hood and gas tank removed for better access.
The thing that gets me, it was running when I shut it down. Now it's stuck. I'd think that it would at least turn by hand. The motor didn't feel hot either.
Open to suggestions. Hoping it won't need an in-frame kit, but if it does, I'll do it.
