Been searching through the old posts about this problem. My loader wont raise at all until I rev the rpms high. And even then its very weak and it bleeds right back off even under the weight of an empty bucket. Also I noticed that the rear arms raised up when I had pressure on the front bucket. I replaced the fluid when I did the brake repair last week. I used permtran fluid, it always seemed to work good in my tractor in the past. Before I start tearing everything apart and checking the hydraulic pump, Im just wondering if its possible that my side control quadrant is out of adjustment. I've never moved the levers since my grandpa had it over 20 years ago. Mine has the 2 spool remote valve under the seat that we always used for the loader and rear hydraulics.
My neighbor claims that masseys have always had very slow hydraulics, but mine has been getting weaker over the years already. I finally had to quit lifting round bales of hay. But its never been so bad that it wont even raise the bucket until now. I dont have any external leaks, checked everything I could find on the outside.
So I'm still just wondering if maybe the side controls need to be moved to different positions??
