Our MF65 with multipower makes a whining noise when the clutch is released to the second stage. It is a continous noise whether the tractor is out of gear or in gear (stationary or moving) or if the MP is hi or low and follows the engine speed. Prior to the noise starting the MP was sporadic - sometime it worked, sometime not (or so it seemed). The noise seems to orginate near the seam between the transmission and differential housings. My guess is that it is the multipower clutch unit but was hoping someone that had a similar problem can confirm (or not) prior to breaking the tractor apart.
