MH30 pto shafts/ clutch?
MH30-WNY
Hoping someone can help me my MH30 just stopped moving out of nowhere. Non of the gears work and the shaft doesnt spin while in gear.
check under battery box if shaft is turning when in gear make sure both ends are turning should use two people [don't run each other over ] if it's not turning clutch or spline is out if shaft one half of the shaft is turning the the coupler is shot if both ends are turning you have trans problem betting its the clutch or shaft or coupling
