Mid-mount scraper blades on tractors?
Gun guru
Has anyone made or bought a mid-mount blade for a tractor for grading gravel roads and driveways? I would love to have a mid-mount scraper blade for doing this. Hydraulic up/down pressure with the tractor weight to get real heavy cutting pressure.
If you have then post a picture or an explantion of how you did it.
here are somepics of a mid mount blade i saw a while back on a cub. i have one of these blades, but it gets used on my b as a snow plow. maybe it would give you some ideas
poke here
poke here
I used the front cultivators on a cub to hang a mid mounted blade on. Used a shank on each side without the shovel. Hung a concave off a Massy Harris 50 clipper combine for the blade in front of the shanks. Set them at an angle, Worked really good for snow and dirt. Going to make another one. rw
I have a picture in a book of an MF workbull with extended front wheels and a bullgrader attachment. Kind of like a smaller grader. Dave
a ford 901 or similar mod. with wide front is a perfect candidate for such a machine. plenty belley clearence and long wheelbase between wheels, plenty room for blade to swivil.
Something like a huber maintainer, can't remember what manufacturers but there were a few either offered by the factory or aftermarket, just can't remember what ones I have seen and who made them. You see them for sale every so often, and seemingly reasonable, as it does not seem there is a lot of em around.
Like this, a modern version, forget they still make these, they go back some years, I thought I have seen Fordsons converted to something like these, and some others, have seen a few different ones, short on memory today.
Huber Maintainer
