Recently we did some work on our 1967 MM G1000 Vista (Diesel) which required us to remove the oil pan. We changed the oil pan gasket before putting the oil pan back in place. Since doing this work, we fired the tractor up and noticed oil fairly steadily running out of the inspection plate at the bottom of the bell housing and around where the oil pan bolts to the bell housing. When we changed the gasket and were cleaning the old gasket off of the bottom of the engine I did notice that the rear engine seal retainer sat slightly higher up than the bottom of the engine casting where the oil pan mounts to (very little but it was a bit higher up and when scraping the old gasket there was a distinct lip/edge at the joint between the bottom of the retainer and the bottom of the crankcase. I have not removed the oil pan again yet but I believe the oil leak is coming from this area. Has anyone had this issue before and if so how did you fix the leak (gasket glue both sides of the new oil pan gasket OR make a thin piece of gasket to go in the recession at the bottom of the retainer, etc.)?
Thanks in advance for your assistance.
