MM U302 L.P. Should I?
in-too-deep
Location
56676
Hey folks, all"s well in northern MN.
Found the above tractor and it"s exactly what I"ve been looking for.
Ampli-torque works, good tires, Oliver loader with bale spear, runs good, but it runs on L.P. (original)
I haven"t heard it run or driven it, but the dealer wants $3950. Oh, it has 2400 hours. My biggest concern is the L.P. Is it worth having to buy a tank and hoses and what-not? Can you even still get set up for filling tractors? I heat my house with fuel oil, so I don"t already have a tank.
I know it"ll be worth more as a collector someday, but right now I"m thinking it"s a good buy because no one wants an L.P. tractor.
Thoughts?
I have some mm's on LP and I like them. They are not that hard to fuel if you have a tank with a liquid withdrawl valve in it. I just bleed mine and the pressure in the big tank will fill the tractor. Lp is a good clean fuel, you don't get dirt and dust like you do with gas, but you can't fill it with a can either, I would like to have one just like you described.
Personally the U302 is my favorite tractor. We have one on LPG along with several others.
They are a very good tractor. LPG burns real smoth and clean. They start well when its warm and cold. Refuleing is not that complicated once you get the hang of it.
The 302 is a very comfortablke perfectly sized tractor.
I say go for it and you will not be disapointed.
