model 39 JD sickle mower
Tony L
I put in a new sickle adjusted and shimmed it out and it cuts good. I am balling up on the end in grass hay. I was told to put a double knife on the end. I mowed thicker hay in the spring with the same mower and did not have a double on the end. I did change tractors but I am at the 540 rpm notch on the rpm gauge. Just weird I guess. Does a double knife make that big of a difference?
Yes, the section-and-a-half on the end of the knife eliminates grass clogs at the outer shoe.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/39N%20Mower/?action=view&current=IMG_0042.jpg" target="_blank">
IMG_0042.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
There is also a stripper plate that can be adjusted on the outer shoe.
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/350%20Mower/Nelson/?action=view&current=IMG_1499.jpg" target="_blank">
IMG_1499.jpg" width="500" height="400" border="0" alt="Photobucket
</a>
Hope this helps and good luck with your <a href="http://www.youtube.com/watch?v=ZLND2DifdD0">39 JD sickle mower</a>.
Ha Ha I don't have a stripper plate or at least one that is wore completely out. I can make another one, Mine is not touching the knife and that is where the grass is catching. There is no adjustment left. I found this mower cutting hay for a friend that bought a farm and it has been an adventure. It is a good mower and now it will be even better. Thanks
I have a JD #38 mower. One other thing to check is the leger plate on the outside shoe. I was having the balling up trouble and the leger plate had gotten lost. I put a new one on and now it works great.
Hope this helps Jeff
My spelling may have been wrong but the ledger plate is the cutting surface under the sickle section to make a shearing action. it is on all the guards and both shoes. Hope this helps Jeff
