MODEL 509 CASE POWER UNIT
HARVEY BURCH
I have a model 509 case power unit . When I try to order a gasket set etc and give the parts dealer the model and serial #'s they have a lot of trouble matching up the numbers to the right parts. Does anyone out there have any suggestions to simplify this procces. Do I need to ask for a certain name brand or what ever can be the problem?
the 509 should have a serial number. When looking up engine parts use the Case 500. Parts book will show the difference in head gaskets. Match head casting numbers with correct head gasket.
caseman-d
You can also buy gaskets from NAPA. You have to buy two head sets for a 400 to get enough gaskets. They don"t list a set for the 500.
IT'S LIKE PULLING TEETH FINDING PARTS FOR THIS THING I GOT A REBUILT HEAD FROM RF ENGINES AND IT CAME WITH NO POWRCELS IN IT NOW I GOT TO FIGURE OUT HOW TO FIX THAT I HAD NO LUCK WITH THE LOCAL NAPA STORE THEY SENT TWO HEAD GASKET SETS AND THEY WEREN'T RIGHT THEY SENT 6 FUEL FILTERS ONE OF THOSE WORKED THEY SENT AN OIL FILTER AND IT DIDN'T WORK WE HAD ALL THE ORINGINAL PART #'S AND IT DIDN'T HELP THE JOHN DEERE PLACE HERE IS GETTING A HEAD GASKET SET TOMORROW HOPE IT IS RIGHT I STILL GOT DEALERS HELPING SO I HOPE WE CAN GET THIS THING RUNNING AGAIN SOON THANKS FOR ALL YOUR HELP I GOT LOGS ON THE DECK AND NEIGHBORS WANTING SOME LUMBER
is it possible to remove the powrcel's from one head and install them into another one i got a rebuilt head but the powrcel is not in it A6320A HEAD MODEL 509 CASE POWER UNIT
THANKS RODGER I ENDED UP GETTING TWO HEAD GASKET SETS HS3103 "VICTOR" IT HAD EVERY THING I NEEDED EXCEPT THE THERMOSTATE GASKET BUT I HAD ONE LEFT FROM A SET I BOUGHT IN 2003 HS3103X THAT HAS NOW BEEN DISCONTINUED I GOT IT FROM A PLACE IN NY THEY WERE THE ONLY ONE THAT COULD MAKE THE MATCH I ORDERED THEM TUESDAY GOT THEM THURSDAY AND CRANKED IT UP TODAY EVERYTHING IS LOOKING GOOD I READ THAT THE 509 WAS FIRST BUILT IN 1953 AND I'VE GOT THE LOWER SER# SO IT'S THE SAME AGE AS ME THANKS AGAIN
Harvey, if you run into a bind again I have a parts book for a 509 I can look things up in for you.
