Don burden
i can not mount the lift arms to plow on my 3910 tractor. the bar balls are to wide for locking pins to mount in lift arms. can the bar be replaced?
any help Don b cedar hill texas
do you know where i could order these. how to remove the old ones thanks DonIf your tractor has the replaceable lower link balls you can replace them with narrower balls.
where in maypearl are you .where is the plow I'm in Maypearl if I can help, I will be glad to
This would be a good time to use the Direct Message feature, then your addresses will be just between you two, not the entire internet.where in maypearl are you .
northwest side of townwhere in maypearl are you .
Your Ford 3910 is a cat ll/l, so it can have either cat ll pin balls or cat l. The hole in the cat ll balls are 1.125" ID. Cat l balls are 7/8 ID. I think they are brand-specificthe plow is old, no name, the shatf has a shoulder on it that stops the ball from clearing the hole.
the ford 3910 is category 1. thanks for your interest Don Burden
