Moline/BF Avery??
Just picked up this tractor, and I am having trouble identifing the exact model or year of it. The rear end of the tractor is BF Avery, but the origional paint is yellow which is not typical of that company from what I understand. I was told by the previous owner that it was a Moline, but I have not been able to find an exact match while researching them. Any insight as to the model, year, or any history of this tractor would be very helpful!
Two serials?? That sounds like right number, starting with V for V-model. BUT, that front axle is not the usual wide front V, almost looks like heavier BF axle. Wondering if adjustable front was option now?? those two "hang-me-down" mounts near rad are like a V, grill looks V shaped. Is there an engine tag on block, tin tag? The V had smaller engine than the others. What's that chute on back for? Looks like FAST way to put gas in tank, ha! Not sure what attachment mounts are hanging on there, but might keep those if you find the attachment that went with it. Mounts are first things missing on most attachments when found. Probly a cultivator originally.
Thomas,
Look on top of the right hand frame rail near the bellhousing area or just in front of it. There should be a serial number stamped into the rail like #V###. Your tractor has the Avery hydraulic system but the later style front axle that was used on most/all the Moline versions. Later Moline versions had a Moline hydraulic system. It is defintely a model V as J. stated above. Production was from 1946 (1V5 starting serial #) to 1952 (7V271 ending serial #). The number may be covered with several layers of paint and could be very difficult to see. It is hand stamped with I think about 1/4" letter/numbers.
Brian
That hopper looks like the one on the John Blue side dresser that came with Mom's BG.
The front axle is correct for a late model V tractor. Mom's V has one just like it. Most, if not all, of the Avery produced tractors has the cast front axle. Many with the cast axle have patches where they have been welded back together.
I am thinking a way to tell if the V was produced after MM bought the company is to look at the top of the grille. If it does not have the mounting holes for the Avery medallion, it was most likely produced after MM bought the company. (Of course there were probably some made that still had the holes too, to use up existing parts.)
Those arms hanging under the tractor are the cultivator arms. The cultivator shanks clamp to them.
Our late 6V### model V has an "MM/Avery" hood badge instead of the earlier "Avery" badge. Was this not common on the late models or did MM drop the badge on the very last ones?
I found the serial number 5v-742. Anyone have any further information on that tractor based on that number? like a year, or correct paint color, because it has been painted red on top of gold.
Thank you for your help,
Thomas Hudson
It is a 1950 model. I wonder since the little Avery tractors came from Cletrac if they used the Cletrac serial number system on these as well. Where are you located? A friend of mine also in Northwest Ohio probably has a dozen of them and can tell you more about them. He does not do the computer. J.
Hi Thomas, we just purchased a tractor that looks just like yours. Where in the world did you eventually find the serial number? We found stuff like VT569 VT570 but obviously those are not the serial numbers. We are a bit confused on where to look.
Thanks! Jacky
I found the serial number on the right frame rail on the top side above the bolts. It was almost across from the bell housing on the motor. Good luck finding info out about the tractor! What condition is yours in, are you planning a restoration?
(quoted from post at 18:37:38 08/04/10) I found the serial number on the right frame rail on the top side above the bolts. It was almost across from the bell housing on the motor. Good luck finding info out about the tractor! What condition is yours in, are you planning a restoration?
list:86a38d1ce8]
Thanks! I did find the serial number where you said it was. The tractor is almost identical to the one you have except it has the metal decal on the front of the grill. Ours turned out to be a 1948 model according to the serial number. We are needing a gas tank but have not had any luck in finding one of those yet. We are planning on restoring it fully.
Jacky[/list:u:86a38d1ce8]
Be instering to know what year the yellow ones are. Mine are all red with the arched axle. 1948 models. When did they go yellow. Maybe original Avery is red and went yellow after MM took over???
(quoted from post at 20:32:56 08/04/10) I have some avery v parts. gas tank etc.
How much do you want for your gas tank and what condition is it in?
My tractor is a 1948, would it work for that year?
