White half track
Thanks for the answers to my last questions. I received my my manual and am reading it prior to pulling the engine on a 1976 449 engined 990. I have read most of it but need some things clarified.
When I pull the injection pump I need to make sure the marks align on the mounting area or make some marks myself. If I pull the injection pump by taking the three bolts out will the gear drop? Are there bolts that hold the gear to the pump? Can the pump only be mounted to the gear on one way? Manual is a little confusing.
Will the injectors come out easily or do I need a special too? Can I reuse the copper washers or need new?
Thanks in advance and again thanks for the prior help. I feel comfortable doing this but like to get everything figured out before starting.
