More baler questions
grandpa Love
International 47. The good, the
bad ,the ugly. Y'all's opinion?
It's only $700. Ol' guy passed
away,farm is for sale... equipment
going ......
Cutter is $500.
I have a 440 international and it?s probably the best little baler I?ve ever used it had been parked in my aunts shed for at least 25 years still had twine it missed 4 bales out of 700 last year blew it off and greased it and it parked it outside all winter hooked on and headed to the field missed 2 bales again and haven?t had any trouble since then they will all miss tie once in awhile or if you shove to heavy a windrow to fast or or if you run in hay that?s way to light driving around a long time trying to pick up enough to make a bale
Hi Grandpa, we had one for about 10 years or so. Traded up from a worn out IH #46 to #47. I didn't like the #47 as well as #46 as the #47 had a short pole and the one piece PTO so you couldn't turn as sharp on the corners. The knotters had the usual early IH knotter problems, keep the twine knife sharp, sensitive to quality of twine, no thick and thin spots and clean all the hay chaff and twine bits out of the knotter everyday or every time you add a ball of twine. On ours the outside knotter liked plastic twine and the inside liked sisal twine. My brother traded it in on an IH #430 with "All Twine" knotters and they rarely missed a bale on either sisal or plastic. A neighbor retired from farming and my brother bought his IH #435 "All Twine" baler that has a wider pickup and more capacity than the #430.
SV, does your IH #440 have the "All Twine" knotters? I noticed in the photo it has the long pole with the two piece PTO that I kie for turning sharp corners without PTO chatter.
Grandpa get me some knotter pictures and I can tell you more. What others said on the hitch and pto shaft is very true. On many of the Ih balers there is lots of parts interchange. Also check the pick up head clutch. (you should go through that)not a big deal. Quite a few IH balers around me and they baled lots of hay 45 was the one to run from. Also they like to run slower than pto speed like 350 instead of 540.
At this stage of the game it about has to work or else it would have been parked outside rusting away. Lots of salvage balers out there to strip parts off of.
If it has the "all twine" knotters retrofitted on the baler its probably pretty good. The original knotters on those balers were not very good and could drive a person to drink if they decided not to work. If the old man had bales of hay on the farm most likely they came from this baler. I have a 47 wire tie baler - it is not near the capacity of the 276 New Holland that replaced it in the starting lineup. The early 440 balers were similar to the 47 in capacity - the later 440 balers and 445 balers would be similar to the 276 New Hollands.
If it can make a bale and tie it that baler would be cheap for NE Kansas even as rough looking as it is. I watched a 46 baler that had been used the summer before (it worked) bring a $1200 at auction. I sold a 46 baler that would only tie on one side (guaranteed) and the guy gave me $200 cash and a cheap handgun for it (Bersa .40 cal).
This one is an all twine . And I didn?t realize they had a one piece shaft available on these . This one you can turn pretty sharp without much chatter I did turn to sharp the other night and blew a shear pin
IH 47 is not the most miserable baler ever (that honor goes to the IH 45), but its right up in there. Look for a New Holland. But buy the mower- its a steal. But as someone else said, you may not have enough power to use it. Needs about 40 HP, and a good 3 point hitch.
Well, it's a 47.... if they're not bullet proof, they need to be shot. Mine has payed for itself a while ago, so I have no complaints. I don't know that I would give more than half of what they are asking for the baler pictured. Those knotters best be near new for that price. No thrower, either. No good. The mower looks ok for the price. Things could get expensive if one or more pods are bad.... & hairy if you can't find parts. Kind of reminds me of a Vicon. Maybe a Taarup?
Mike
That is a good price on that disc mower, you better check the shells for play, and the gear box. But in reading about your collection of tractors I don?t believe you got the ponies under the hood in any of your tractors to lift or run it.
