More Ford alternator questions
grandpa Love
Got the one wire alternators on both the 640 and the 960. They are wired different. The 640 amp gauge works and alternator is charging. The 960 gauge doesn't move. Multi tester I bought shows 12.85 on battery with tractor off. When I start it the numbers go up and down from 5.50 to 14.70. Never staying steady. Is the wiring wrong on the 960?
Alternator needs to go to the ammeter, same terminal as the key switch like your 640, or it doesn't pass through the ammeter and show if it goes direct to the solenoid. Wire it like your 640.
The 640 is wired correctly.
The 960 will work as wired, it just doesn't indicate charge. The alternator is wired directly to the battery and not passing through the amp meter.
The fluctuating readout is one of the problems with digital meters. What is happening, either you are not making good connection with the leads, or the regulator is modulating the voltage, confusing the circuitry in the meter.
Try turning on a load, like the headlights, see if that will stabilize the reading.
Amp Meter Wiring
