I need a few more rpms on my wd 45. I have the good spring already. I want to work on the weights but need some good advice on how and what to do. exactly how much and where to grind weights. Everybody says you have to be very careful. any advice are pictures would be greatfully appreciated also if anybody has parts already fixed I might be interested.Thanks in advance. Have a good day!!!! Tommy in NC.
more rpms = bigger carb. CFM=(rpm x Cid)/3456. been trying to tell you fellow allis pullers that the 464 carb isnt the answere but no one listens. lol
Thanks Mitch I must have missed your responce about the 464 carb.What kind of carb do I need and do you think I should leave my governor alone.I knew you would reply and I always appreciate your help.Have you pulled your Allis yet and how did it do?Thanks Tommy in NC
I hooked to the sled saturday in 4000 lbs . couldnt move it for spinning in any gear at any rpm . I would either use a carb like a 901 ford or probably a g moline carb for best results on a small motor.
