Since my '39 block is completely bare now, I decided last night to remove the welsch plugs and get as much rust and sediment out of the water jacket as possible - you simply would not believe all that came out. I'll bet I could have filled up a two liter bottle with all of the sediment and rust flakes. It is doubtfull any water circulation/cooling was done at all with the back half. I used my compressor and a cone tipped blower attachement to shoot compressed air in through every hole in the block - stuff was flying everywhere in my garage and took quite some time to sweep/clean up. Anyway, I discovered the water jacket holes close to the valves were completely clogged (you know, the shallow ones on the far right edge of the block). I tried a pick, no go. I tried a small flathead screwdriver, no go. I tried a Dremel with a metal shaping spiral bit and that did work to get the hard mineral deposits out. However; I could only get as much as I could angle the Dremel, which wasn't enough to clear the passageways for many of the connecting holes. Trying to figure out what else I could use, I decided to turn to chemical assistance. I got out the C-L-R (Calcium, Lime, Rust dissolver) and poured it down into the clogged holes after checking to make sure it did not say NOT to use it on cast iron. WOW, is about all I can say - that stuff boiled up like one of those elementary school science fair volcanos! Let the stuff sit overnight and all but three of the holes were cleared up this morning. I saw no damage to the cast iron, so I guess it worked out well.
Just thought I would pass this on for public knowledge.
Dan
Dan
