I have not seen a mosquito all this year. Our control has been lacking moisture. Not recommended!Anyone here have a proven mosquito control pesticide mix to be used near homes and around barns?there are a lot of options but I’m looking for what works.is malathion something I can use
If you are feeling lonely we can send you a box of mosquitoes. We have plenty to share.I havent seen a mosquito here in Iowa for several years and i spend a lot of time on the patio.
Been using these in five gallon buckets this year. They have reduced the amount of skeeters but still have plenty yet...
I think they have all died off and i dont want to reintroduce them like wolfs out west. LOLIf you are feeling lonely we can send you a box of mosquitoes. We have plenty to share.
When I was 14, I was driving the 64 Chevy half ton with the 6 banger engine.Anyone here have a proven mosquito control pesticide mix to be used near homes and around barns?there are a lot of options but I’m looking for what works.is malathion something I can use?
John, I was born and grew up on the Texas coast. I made it one of my life long desires to move inland away from the humidity and mosquitoes. Mission accomplished.If you are feeling lonely we can send you a box of mosquitoes. We have plenty to share.
I wouldn't think of saving wetlands as increasing the number or size. Detention ponds and rain gardens don't catch and hold water, they only slow the flow down and enhance absorption into the soil. Mosquitoes would have to breed and mature extremely rapidly in both of them to increase population.With all the "Saving wetlands, dentention ponds, rain gardens", programs, I suspect we will see an upswing in their population, in the future.
Yeah, when I lived in central MN we could count on a fresh mosquito hatch after any big summer rain storm. Mosquito eggs need about a full week of standing water to hatch.I wouldn't think of saving wetlands as increasing the number or size. Detention ponds and rain gardens don't catch and hold water, they only slow the flow down and enhance absorption into the soil. Mosquitoes would have to breed and mature extremely rapidly in both of them to increase population.
In this area, they quite often don't completely dry out, many years, due to our climate.I wouldn't think of saving wetlands as increasing the number or size. Detention ponds and rain gardens don't catch and hold water, they only slow the flow down and enhance absorption into the soil. Mosquitoes would have to breed and mature extremely rapidly in both of them to increase population.
You've got my attention. I understand how Richard G and MeanGene's chebbie trucks knock them out but I'd like you the explain how dunks and 5 gallon buckets work.Been using these in five gallon buckets this year. They have reduced the amount of skeeters but still have plenty yet...
Ok, so can I interest you in a box of chiggers? Unlike wolves and skeeters,you will never hear nor see them,regardless how many are around.I think they have all died off and i dont want to reintroduce them like wolfs out west. LOL
That is very strange. The design engineers factor in climate, rainfall, drainage area, soils, etc.etc. when designing them, and then they have construction engineers overseeing construction, making sure that correct materials are used, etc. There would be no point to building them if they weren't done right. Where did you read about this?In this area, they quite often don't completely dry out, many years, due to our climate.
Well, I am a retired engineer, and installed retention ponds since they were thought up, as part of engineered drainage systems, and have bid a lot of them. I installed some at Google, Facebook, Stanford Linear Accelerator, and the New Bay Bridge/ Yerba Buena Island/Coast Guard Station just to name-drop a few lol. They do by design catch and hold water for a limited time, with the intent of having as much as possible soak into the ground instead of running off, and trying to build them to hold a best-estimate ("factor in" AKA best estimate) of an average rainstorm's water volume- in a heavier than normal storm, it can run out the overflow drain. I ran into an interesting one in San Francisco, building a new soccer field at San Francisco State- who in their wisdom, did not want ANY water falling on the field soaking into the ground- I was told that that edict came from the City. I had to build the subgrade and field dead level, and install a complete pond liner membrane with hot-welded and smoke-tested joints, including through the drain system trenches across the field. Then had to build up the field with 100% pea gravel, again dead level. You should try to grade pea gravel with a motor grader to a 1/4" per 10 feet standard measured in any direction- I did it myself with an old-school laser on a 140H blade, no GPSThat is very strange. The design engineers factor in climate, rainfall, drainage area, soils, etc.etc. when designing them, and then they have construction engineers overseeing construction, making sure that correct materials are used, etc. There would be no point to building them if they weren't done right. Where did you read about this?
Ok, the idea is they work on the larva stage. The adult mosquito lays their eggs in non moving water. The hatchlings live in the water for a time before becoming adults. The dunks consist of a bacteria that attacks and kills the larva. The trick is to have only water around your area that has the dunks in it. In my case we still have some low lying areas in the terrain that doesn't get the dunks so I still get some of the pesky things but using these has reduced them...You've got my attention. I understand how Richard G and MeanGene's chebbie trucks knock them out but I'd like you the explain how dunks and 5 gallon buckets work.
