motor oil ruining cams
t-mark
I don"t know if this subject has ever been on here before, so here goes. I heard from a guy at work today that the newer motor oils have reduced ZDDP(a zinc/phosphorous compound)so much that it is causing damage to camshafts on many older(pre '89) engines. Has anyone heard of this, and if so, what is your opinions on it. I understand there is an additive you can put in to replace it.
Use good oil and your cam will be fine. Sounds like a whole lotta hype to me. I guess maybe the super duper synthetics could do something funny to it but still doubtful.
Yerpearnoid,
You might want to do a little reasearch before saying there's NO PROBLEM.
For one source, take a look at the link below. LOTS of big names in the cam and automotive industry seem to disagree with you.
A litle surfing around GOOGLE will bring up LOTS more.
New
T:
This is a well known issue caused by ignorant federal bureaucrats.
Though probably not a serious concern for us antique tractor enthusiasts becasue our slow speed gasoline tractor engines are equipped with low pressure valve springs, it is a serious concern for flat tappet vintage muscle car engines.
To avoid the potential problem, use 15W40 diesel spec oil in your flat tappet vintage tractor engines.
Stay tuned for a pending real debacle as the feds have mandated that the zinc additive be removed from diesel spec oils in 2010 (2011?).
Don't you just love these dolts?
Dean
Many 15W 40 diesel spec oils already have lowered the ZDDP below what is needed for flat cam followers. This includes Shell Rotella T "Triple Protection." The newest forumla that says "Triple Protection" on the label has the low ZDDP content. The older forumla is still made and is very popular in Europe. I don't find it anywhere in my area anymore unless I special order it.
The fact is - you have to look closely at any oil you buy - diesel-rated or not. Many of the most popular brands have shifted their formulas to conform with the post 2007 diesel emission systems - which is not good for older engines - gas or diesel - with flat cam followers.
Older engines need oil at over .1% ZDDP. The new Shell Rotella T does not have it since it only has .05%. The older formula Shell Rotella T has .12%.
The newest formula Mobil 1 Turbo-Diesel Truck oil has .11 % ZDDP. I might change over to that once I run out of old forumla Rotella.
So, did I get this right? We have the flat-tappet cams in our old ford tractors, but it's probably not an issue because of the low-pressure valve springs. BTW I have a '64 4000(4 cyl.)
Thanks Bob for the info. I did read the articles.
Q) "flat" tappet cams... are they anything other than "roller" tappets/cams?
I've come to the place in life that i have my oil changed now. Had used castrol since i had a full head of hair....sl
If you are asking about the difference between "Roller" and "Flat Tappets", Roller tappets have a roller bearing on their bottom that rolls over the cam lobes. Flat tappets have no roller bearing and just slide over the lobes.
