MT, HYDRAULIC FLUID TYPE
20wt non-detergent is perfectly fine...
In TX, The Colorado Cty Oil Company sells it by the case, 12 per case...think it takes 4.5 pints or so...just do not use something with a detergent/agent in it bc it will foam-up on you and that is not good in the pressurized part [valve-housing] side of the TOM
regards
tstex
Thanks for all the good info. Tractor Supply here might have it if I ask the right person that works there. If not, 10W-30 might be my route. Again, thanks to all.
