MTA wont stay running
Case e
My MTA sat a while so I drained the fuel tank, cleaned the sediment bowl and strainer, flushed the fuel line and drained the carb. It will start right off after it sits a while but will only run less than a minute. If I pull the choke it will go just a little longer but thats is. Any ideas? It ran pretty well when I put it away so it has to something simple, I hope!
there is a screen at the end of the fuel line at the carb brass nut between fuel line and carb take it out and clean it.
