muir-hill 101
Anonymous-0
can somebody tell me what tractor muir-hill used for the conversion for the 101 i wrote to small holder and loyd loaders small holder said it was a 5000 series but 5000 only has a four cylinder engine my tractor has a 6 cylinder ford diesel .
thanks
(reply to post at 15:47:51 04/13/10)
hey used a ford 5000 transmission and backend in the 101 and 121 muir hill i think the internals were 5000,the 121 had a ford 380 engine the 101 may have the same engine,
thanks for the reply i am trying to find out what
ford manual would work the best , my rock shaft
doesent work and i need to figure out why
Casestudy is correct, they used the 5000 backend, and their own drop box to mate to either a Ford or Perkins engine depending on the model. Most 121's had an assistor ram to increase lift capacity. Not sure about the 101 but I'd guess it also used the 5000 backend.
Chris
when i got the tractor home i found that the previous owner had the 3 point hitch locked out in the up position with some metal rods that ran between the rock shaft arms and the draw bar support why i dont know when i removed the braces the rock shaft lowered so i started the tractor and after working the lever a couple of times the 3 point raised now it wont go down even with some pretty good down pressure i am thinking that there must be something wrong inside the rock shaft housing
I’d check all the easy stuff first….try it in position and draft, is the oil level good, filters? Try and get something heavy on it and work it if it’s been stuck up for a long time.
Those rods that you mentioned from the rock shaft to the drawbar…..are you sure they are not part or the early type drawbar pickup hitch???? I’ve never see one here, but many UK tractors had a large hook draw bar…..early ones were raised and lowered by rods connected to the rock shaft arms. There was a latch type lever that you pulled, and you could drop the hook, back under a trailer/implement with a ring end, then pick it up (by operating the 3pt) without getting off the tractor. These used to rust up/jam up pretty good! The hook was interchangeable with a normal clevis end. It’s been a long time, so my description is probably a bit sketchy, but could it have one of these? The whole draw bar receiver under the axle would hinge down. (I don’t mean one of those little 8n type flat bars).
If nothing else works then you’ve probably got to lift the top cover and check it out inside. Look on the Ford forum for info on this.
Chris
