Mulch storage
Rick Kr
I usually keep a couple of pallets of bagged mulch around when planting trees for people.
Its now cold enough in the barn I noticed the moisture in the bags has frozen. The bags have small 1/4" holes here and there. Obviously not enough to get all the moisture out.
This got me to wondering, could I have a problem with the mulch catching fire like wet hay does?
Its not a problem to move it outside and tarp it, just didn't want to go though the extra work if I didn't have too.
Thanks,
Rick
Not likely to cause a fire. Hay spontaneously combusts due to bacterial action in damp parts raising the temperature to the flash point. The bacterial action is so fast due to an ideal carbon:nitrogen ratio (around 30:1). Mulch will normally have a much higher carbon:nitrogen ratio and so bacterial action will be much slower and not likely to generate enough heat to combust.
HTH
Christopher
You won't have to worry with bagged mulch on pallets. Mulch is rarely a problem unless it's fresh and in large piles like at the point of manufacture. There's usually a lot more moisture in mulch, so even if it does get hot, it has to evaporate a lot of moisture before it can burn.
Thanks for the info.
With the warm weather, I might end up using some more of it up.
Just had to ask though, a hay barn burnt to the ground around here 2 years ago and almost took the house with it.
Rick
