Murray riding mower blade spindles
Lance J.
Hey guys, I have another question regarding my Murray 12hp/38 inch cut riding mower. The blade spindles (Murray calls them Jackshaft housings) are worn and loose and I am going to put new ones on. I have located some spindles on Ebay, the description says they replace part # 92574. Thay look like they would bolt up and as an added bonus they have grease fittings. Now, this machine is from the early 90's and the original parts list and owner's manual are long since lost. I downloaded some off the Murray website for their current model and it seems to have carried over with few changes.
Do you guys think that the new spindles I found will work on my mower? I would think that these parts are pretty standard throught the years. The model number of my machine is 38608x12b, the date of manufacture is 0750. Thanks in advance.
The part# I gave you is for the whole 9 yards,or you can buy shaft,bearings or seals seperate,if hub bore for bearings worn from bearings spinning in same,replace whole unit,if you goto link & do part# search,when listing of items comes up double click each item,will have pic of item along with part# of oem part it replaces.
You can go to yout local Briggs dealer and get an OEM part, for $21.95. hmmm, why buy aftermarket, by mail order with no support, at the same price, pay shipping, when you can buy OEM, with a warranty, locally, then if you have a problem, you deal locally to get it fixed. Makes no sense why people do not want to support local businesses. But, by golly, if the part fails, then they want to go to the local dealer to warranty it for you! It is now Murray part number 492574MA. the new OEM ones also have grease fittings in them.
Jim
