My Ford Tractor what is it?
Dave Gray
I have an old Ford tractor can't find serial # on it but have a few casting numbers on it : EAE 6015-J, NGA 7006 B, NCA - 4024 E, NCA 501 can anyone tell me what I got?
I have looked there they did identify one of the castings EAE 6015-J said it was a 1953-1957 that was all still don't know the model
also was told it was a 600 but the hood emblem does not have the hundred series at top of emblem,just has the Ford wheat symbles in center
look on the block above and left of the starter -
The numbers are usually not stamped very deep (or very straight). Try different angles and light sources to make the number visible. There will always be either a star or a diamond at the beginning and at the end of the serial number. You will only see the diamonds on 8N tractors with a serial number after 8N 433578. All earlier 9N-2N-8N models have the stars. All models made after the 8N will have the diamond markers. The format for the serial number on the 9N-2N-8N tractors is *8N12345*. All serial numbers will begin with either 9N or 8N followed by the number. There are no 2N serial numbers; all 2N tractors retained the 9N serial numbers
the sn's not on the block unless it is a 53 or earlier machine.
it's on the bellhousing (clutch ) aft of the starter.
soundguy
