Jamie in NC
Well, I guess the stars aligned just right and I need to go get a lottery ticket, but both of my tractors head gaskets seem to need replacing. My NAA lost power and seemed to be missing after I was moving dirt with the box blade. I checked ignition and had spark on all 4. I thought the valves needed adjusting, but did a compression test first and came up 120/30/30/115 and heard a whoosing sound from 2 and 3 spark plug holes. I guess the gasket is blown between 2 and 3.
My 860 is leaking antifreeze down behind the coil from the gasket between 2 and 3.
I guess my question is, that is this a common problem for head gaskets to blow or is this an anomaly? I have had the NAA for 22 years and other than normal maintenance, no real issues except the leaking rear wheel seal that I cant get stopped.
Is there a good gasket to get so I dont make this a yearly item?
