The saga of the cracked piston continues....
I pulled out the offending piston. It was not cracked all the way through. Hard to tell if it is a crack or a defect from when the piston was forged.
I took a look at the connecting rod bearings and they show wear. It has worn through to the copper in a couple spots.
Does the copper showing mean the bearing is at the end of its life or is it possible it will run for a long time that way (there was no knock and good oil pressure prior to the tear down)?
I meaured the crankpin at 2.278 . The spec on the pin is 2.2978-2.2986.
Does this mean I want .02 undersized bearings (2.2978-2.278 = .0198)?
Do the bearing really just slip into the connecting rod on a slot? No tools?
Thanks for the help,
-Dave
-Dave
