NAA distributor parts
Pknapp
I just picked up a 1953 NAA with Wagner FEL,Sherman
overdrive,and Howard transmission. In the process of
tuning it up I found excessive play in the distributor shaft. Does anyone know of a source for the distributor bushings and drive gear rivet?
Thanks, Pete
I think you will need to get the parts needed to rebuild the dist from your local New Holland dealer. With the bushing; seal; oring; and thrust washer you are looking right at $50. The rivet can come from any local hardware store; just ask for a round 1/8 x 7/8 inches rivet.
If you find your shaft is worn you can get that aftermarket.
