Name that part
grandpa Love
Need help figuring out what this stuff is. Anyone recognizes the magneto numbers? Or carbs? Or any of it?
Pile of Marvel carb parts worth anything? Wheel weights?
Planter seed plates in first picture on second row of pics, Covington planter plates, Ill buy them from you !
Top left picture I have a number of those weights and never have found what there off of.
As for the carb if cheap yes worth getting and keeping. I took a carb from an Oliver 60 and part of a carb off and 8N Ford amd made a working carb for the Oliver 60. Many carb you can take parts and piece of and make a good carb out of junk ones. BTDT many times
Not positive but I think the top left weights are wheel weights from a trailing disc turner for super a At least they look like the wheel weights we had on ours. Bolted thru the rear steel wheel on the plow. Wheel had a place for 3 of them. 1/2 of the weight was on each side of wheel.
top left picture. wheel weights for 16" thru 20"wheels used on JD and Oliver/M M combines. will also fit front tractor wheels and many other applications if rim has 4 bolt holes. takes two people to mount unless you are good at growing back fingernails!! 8 per set, weigh approx 75 lbs each.
