NATPA Wheelie Bars
PullinDeere
I am building a set of wheelie bars for a JD B and I came across this picture and was wondering if something like this would be NATPA legal? The rule is wheelie bars can't be connected to the drawbar. I have mine welded up already but I need a little more support on the bottom.
First off, I am not a tech guy. I would go on to say this setup is not Natpa legal. The reason being, the wheelie bars and the drawbar frame are tied together. Yes you pull off the drawbar with the loop in it but that is supported by the drawbar frame. In the event of a problem or failure with any of the drawbar system, the wheelie bars run the risk of being compromised since they are tied together. I have the weight brackets on the wheelie bars as in the picture but the complete drawbar and frame seperate. Following after the NTPA, PPL, Outlaw, Bush etc type group for safety is a good idea. Hope this helps. Jeff
The last time I read the rules it did not say it was illegal to connect the wheelie bars and drawbar it just said that they advised against it and I've seen lots of them tied together.
Jim
4. Wheelie bars are required in Divisions II, IIT, III, IV & V and (should not be attached to the draw bar in any way). Minimum requirements for the wheelie bars are as follows. 10" maximum above ground. The back of the wheelie bar is to extend 5" behind the tire radius. C: Pads = 5" square minimum, spaced minimum of 20" from outside each pad. D: Stabilizer bar system must be able to support the weight of the tractor in the heaviest class pulled. E: Jacking up the pads so the tractor is completely off the ground is a good test of the strength of the system’s support ability and the NATPA Tech Crew reserves the right to perform this test at its discretion.
This is the setup I made for our A. Its a little heavier than a lot of guys want but we pull 7500-9500 regularly and it will support it if it needs to. I can fit 8 100 pound weights on each side but that depends on the style weight you use. It is not attached to the hitch at all.
The issue is exactly what you ran into... You need more support.. The hitch frame is the strongest part...
The rule is up for interpretation.. As posted by BigMotor.. It says drawbar.. Not hitch frame..
I don't pull NATPA.. But there have been no issues in 10 years with that setup.. I don't plan to change it any time soon..
