Need Auto-lite generator info....
MEANJDK
I have a 6 volt Auto-lite generator with a cut-out/relay on it. The bearings are getting noisy/rough. I would like to get a rebuild kit. Tag on generator - GBM 4804B 5 8C.
It has one wire coming out, and one threaded post.
Who or where can I get one from? I"ve searched around on here, no luck. Ebay, nada. Google, nada. I found a rebuilt one at NAPA for $196. I believe there is a less expensive solution to what I need. Can someone help me out. Thanks, Jim.
I just replaced the bearings on exactly what you describe though it was from a Case SC a couple months ago. The bearing I had going bad was the ball bearing race in the pulley end. All I did was remove the old bearing and from the parts that were left over (was a rude removal operation) I measured the ID. the OD and the thickness then went to Applied Industrial Technologies (the old Bearings Inc group) and they had one (sealed) that would fit in stock.
You don't need a kit, just a common ball bearing, possibly a bushing, and a brush set.
I can PROBABLY find the numbers Standard Ignition
numbers for you, if you can wait a day or two.
Or give this outfit a call:
Weitzel's D.C. Electric
Norwalk, Ohio
419-668-2844
Toll Free 1-866-840-2844
Open 8:00-5:00 Monday- Friday.
Saturday 8:00 to Noon
Closed Sundays
GBM 4804B apparently was originally used on Massey Ponies and VA Cases.
Generator Kit... Wilson # 36-06-9111
Brush Set... Standard Ignition # EX-39
Rear Bushing... Standard Ignition rear bushing # X-4278
Front Bearing... Generic "203" generator/alternator bearing
Lots of auto supply stores sell Standard Ignition, and could order the parts for you, or cross the Standard Ignition #'s over to the brand they handle.
Check out the Wilson site and contact them to find a reseller in your area, if you want to order a kit.
Bob - Where did you get the information on the Autolite generators? I could really use Autolite cross-references and application charts!!!
