I have a 2840 I just picked up last week. The engine was rebuilt before i got it, and runs GREAT. But, after the owners installed the engine, they started it and there is hydraulic fluid coming out of the bottom of the bellhousing out the drain hole. It is not motor oil, but hydraulic fluid.
I am assuming that they replaced all the engine parts, but accidentally moved something aorund on the bellhousing, and now something leaks. I have no idea whats behind the bellhousing on the diff side. Any clues on what it could be? It leaks a little, but when you shut it off, it leaks about 1/2 cup then stops.
Signed, retired ase master techincian with ZERO tractor knowledge on the case halves. (I did a recent engine rebuild while the engine was not removed from tractor, it was a Massey F MF40, and that I can do, but never split case halves.)
