Need help buying baler
GLSNC
I have about 7-8 acres of fescue in place that I've been bushhogging and buying other people's hay for my horses, b/c I couldn't get anyone to bale my hay (small acreage and I wanted part of the hay). I want to buy a small baler that I can pull okay with my Ford NAA (Jubilee) tractor (26 hp when new) and do it myself. Can anybody recommend a square baler that my tractor could handle?
Pretty much none. That said yes it has been done but its hard on the tractor and the baler also. Now if you where to find and old JD 14T or 24T with its own engine then you can do it easy but with out the engine its all your Jubilee will want to pull the baler and make it work. I stopped using my 841 to bale with because it was all it wanted. Non live PTO on your tractor and the low HP is a problem. Ya theres been many a bale done behind even smaller tractors but its hard on the machines
Hobby farm
Do you have some money to spend on equipment. For instance. I have a J.D. 3020. $6500.00. Baler N.H. 273.. $1200.00. Not to mention your cutter of choice and rake which if looking could pick up both for under 1000.00. That said. You can buy alot of hay for 10000.00. How much do you need to keep your horses. SOmething else just came to mind is fescue isnt the best for horses I"ve heard.
But do you have some money to spend. Maybe trade in jubilee for bigger tractor??
That's just the kind of info I needed. I appreciate your insight. I'll have to look for a baler that has it's own engine. Or I can keep my eyes open for a stronger tractor. I didn't think about the fact it doesn't have a live pto. I'm in no rush, as I don't plan to bale the fall hay unless just some for practice, but was thinking ahead to spring. Thanks again for the info.
I should have mentioned cost. I buy about 300 bales per year. At $5 per, I spend about $1500 for good hay. I figure I could supply my own needs and maybe have a few to sell. I want to keep the cost as low as possible without buying a piece of junk that costs more in repairs, time and aggravation than it's worth. Does your baler have a separate engine? Where are you located? I'm in the Concord, NC area.
It sounds like I'll have to get a baler with an engine on it unless I upgrade the tractor. I looked at some pics of the NH 273 and they all ran off the pto, though they're well spoken of. I'm in no hurry, I may keep my eyes open for a little stonger tractor if I don't run across a baler that will work.
Do a search on feeding endophyte-infected (most is) Fescue to horses; it's definitely not recommended for brood mares and can cause problems in all horses. Of course, I suppose you could sell it to a........hobby-type.........cattle person (most commercial cattle producers raise and save their own around 'here') and buy hay for your horses.
If you can find your self an Oliver 77 or 88 or one of the super models of those they make very good baler tractors and can be picked up for around $1000-1500. They have both the weigh and HP plus live PTO. I have used my 77 for baling hay and even though its rated at less HP them my ford 841, which is 45HP it does a better job and the 77 is 38HP. I have baled hay now for about 28 years and have owned and tried lots of balers and tractor combo and learned the hard way what works well and what does not
Hobby farm
I suggest that you just research your expenses. I have a neighbor that I used to bushhog his pasture for a very reasonable price. He decided I was too high. He bought tractor, bushhog, fuel, grease, parts, time, and repairs. First day broke the bushhog. Tractor lift quit working. Told me wished he had just kept letting me do it. I have a hay operation here in Georgia. You just dont realize the expense and upkeep until you jump in. Fertilizer is the biggie. Grass wont make good hay with out fert. and water. I suggest you continue to buy from your local farmer and let him take the risk and expense out of it. Just my thoughts unless you are rich. Good luck.
Some folks have rightly pointed out the expenses involved that might make it costly hay, but no one has addressed the fun factor. If you have the time and inclination, what you want to do could be a lot of fun. That's why people hobby farm.
I already have a tractor and I think I should be able to get a decent older baler for less than $1,500. The problem is might be finding a baler that my tractor can operate adequately (I've learned from another poster that I probably need one with it's own engine to run the baler). A sickle mower (probably won"t invest in a haybine) and rake can probably be found for not much more than another $1,000. Without repairs, I would have payback in the second year. Repairs on the baler are my major concern, as I hear they have frequent problems and are difficult to work on. I do have a barn to keep them out of the weather. The difference between me and your neighbor is that I doubt you charge him $1,500 annually to bushhog. That's what I pay for hay. I recognize your point, though. Thanks.
i pulled a jd 14 T behind my wd allis for ages. It is about 7 hp more than the 8N. power is not the problem. Speeds are! Being able to slow down the tractor and keep rpms high . That is the reason i bout the 8 speed D 17. I bought a #3 allis mower for $35.oo that i wouldnt trade for anything.i bought a hay rake pto powered with a tedder .I sold the 14t when i moved and regret it.Either getting the motor driven or buying a tractor with more speeds should work. or just being careful when you se a slug of hay that might make it shear a shear bolt. part of the art and craft of farming is making use of what you have and learning tricks to work with it. its also cheaper. lol
We've run a NH 268 and an Oliver 60T with wagon behind with a JD B and a Farmall 200. Neither of those tractors is a powerhouse. Balers don't take a great ampount of power if you're not pushing the hay thru them. Tractor weight can become a concern if you have hilly land. Live PTO is nice, but you can do without if you are careful to get baler up to speed before you pick up windrow, and don't try to plug the baler with oversized bunches of hay. Recently acquired a MF 180 which just plays with the baler and wagon.
I use an old New Holland baler with a motor on it. Mostly with a Ford 8N but I have pulled it with my Farmall Cub on flat ground and it did ok.
I would be glad to get 3.50-4.00 for my hay, they have alfalfa in the local paper for sale for 2.25 to 3.00 per bale. I can't really even break even at that price. DOUG
For a PTO powered baler: A NH 65 would be my first recommendation. Second recommendation would be a Ford 520 although parts will be difficult to find for it. Both of these balers have a slightly smaller than standard bale chamber (12"x16") instead of (14"x18") or (16"x18") like all other balers will have. The benefits are that the smaller plunger takes less power to run and also does not shake the tractor as much as there is less mass changing directions.
I run a NH 65 compact baler behind my Kubota L285 (26.45 PTO hp) and it does fine. My tractor is smaller and lighter than your NAA and handles it easy. I do not tow a wagon, but I think I could if I had one. My tractor does not have Live PTO and this does not pose a problem for me. If I have a problem then I simply zig out of the windrow and zag back in later - I never clutch. I will simply bale my missed spot later as I work my way around my field. In my opinion your tractors biggest weakness will be that it is almost too fast in 1st gear - My Kubota has slower gears which help me. You will have to rake very carefully in order to not have your windrows too big due to this - but it is doable.
Engine powered baler: Almost anything should be okay if you are on flat ground as you will only be towing the baler as the baler's engine will be providing power too. Personally I did not want another engine to maintain so I chose not to go this route.
If you like to tinker with old machinery it can be a fun as well as relatively inexpensive project. If you are not mechanically inclined then it can be a nightmare working with old stuff if you do not enjoy it. I have less than $300 invested in my baling operation so far (not counting my time restoring my old equipment which I truly enjoyed doing anyway. Pics of my baler and rake are on this site. My first 2 hayings I simply used my bush hog to cut - less than ideal but it worked. Hope to have an old sickle bar mower operational for next year though.
If money is no object: Then Farmstar or MicroStar makes brand new mini-balers that work behind really tiny itty bitty tractors for like $15000 but that is way too pricey for me.
Fescue for horses: I am no expert here, but I guess horses must have only ate alfalfa back when they were wild animals before humans domesticated them - LOL. Fescue can be fine as long as it is the right types of fescue as that is actually what wild horses would be eating. The most critical factor for horse hay of any type is to insure that it is not moldy as horses are subject to respiratory infections. In other words it did not get rained on during the baling process and was baled at the proper moisture level. Another benefit to doing you own hay is you will definitely know if the hay was rained on or not. Rained on hay is still usable for cows only.
WD is 34HP and has live PTO where a Ford Jubilee is a little smaller and NO live PTO and that is a big difference. BTDT and live PTO makes for one that will do the job and one that will try
Ok lets brake this down a good bit more. A good working sickle mower can be found for $300-3000 and that includes MOCOs/haybines. I have a NH460 MOCO that I payed $500 for and have used it for years but I also work on it off and on a bit but thats normal if you use something. A hay rake can be found for $150-3000 depending on what it is and where you look. Balers can be picked up for $150-20,000 all depends on what it is and how new it is. I bale with a NH271 that was up till 2 years ago a fence row baler and I took the time to bring it back into service.
Get a real tractor. Or find a baler with it's own motor.
We had a Jubilee and we never considered putting the baler on it never.
I run a 24T or a MF 3 behind my WD Allis and it is barely enough. Rarely do I pull a wagon behind the baler.
An 8N is underpowered under weighted and has really poor gear selections.
Trade up to an 801 and you might have something.
For just doing you own hay your NAA would probably pull most small square balers on the flat. I have baled hay for many years with my ford 860 about 40hp and it has easily pulled IH46,IH435,NH68, and NH268. And when I needed to I have hooked my farmall super C to the balers and still baled hay. The super C is probably in your horse power range. It works harder than the 860 but I still do not believe I am being hard on the tractor. You may only be cutting 2 times a year and are not custom baling to make money, so if it takes a little longer(and it would be very little longer) to bale than the guys with the bigger rigs why change your tractor out when I am sure it does other chores for you just fine.
Great information. Thanks. Based on the very helpful responses, I will probably just take my time and look for either a baler with its own engine or a stronger tractor. My Jubilee is in excellent condition and these are in some demand, so I may be able to buy a stonger tractor that is less in demand and not spend too much more money after selling the Jubilee. Finding a baler with an engine really limits my search and I"m not all that keen on maintaining another engine that will be used once or twice a year. But I really like my tractor, it"s the only one I"ve owned, and I know it well mechanically. The information I"ve received here has really educated me on my options and limitations.
If you like your NAA and it does eveything else that you need it do well then I would not even consider selling it if it is mechanically good shape. Apparently, you already know that your tractor is a good tractor. However, if you like the old Fords finding a 650 series would only be the newer version of your NAA - it would have the 5 speed tranny with a slower 1st gear but still no live PTO. A 660 series would have the 5 speed tranny and live PTO via a 2-stage clutch (same for the 800 series).
Live PTO is nice, but it is not mandatory as long as you do not make the mistake of creating monster windrows that are going to choke the baler to the point that you either need to clutch to let the baler catch up (clutching is not an option for us as we do not have live PTO) or choose a slower 1st gear (will not be an option for you since your current tractor does not have). As you know these facts in advance all you need to do is simply rake small windrows and you will be okay - it just takes a little more skill and advance planning when you are raking your field. Keep your windrows small and you will not have any problem on the few acres that you are planning to hay. Even if you mess up with the raking in a few areas and get the windrows too big, then simply zig out of the windrow as needed in theses areas, to avoid clutching the tractor - bale your missed spots later.
A PTO baler of the proper size will not hurt your tactor in any way. My bushog puts more driveline strain on my tractor than my compact baler does. I am even baling with a compact tractor that has less mass and driveline strength than your tractor does.
Pick the wrong baler though and you could have issues such as not enough horsepower and the baler shaking the tractor excessively which would be hard on the tractor (any baler is going to shake a little due to laws of physics with the plunger changing directions). Balers come in low capacity, mid-capacity, and high capacity - Definitely stick to the low capacity units. I simply opted to to choose the smallest lowest capacity baler that I could purchase cheaply. The NH 65 and the little Ford 520 balers were actually even targeted for the small farmer that had N's, NAA's, and 600's series tractors that were common to the average small farmer in the late 1950's and 1960's. The NH 65 is even easy to still get parts for as it shares many parts with New Hollands bigger balers and was built from 1960 to 1965. The design is a smaller version of NH 200 series of balers - It is not like most of NH older 2 digit model series of balers which had lots of wood in them for bearings.
Picking a baler is kinda like picking a camping trailer to pull behind a pick-up truck. If you have a small 1/2 ton truck with a small v-6 engine, you pick a small lightweight trailer out of necessity in order to tow it safely even on flat land. If towing through hills and mountains you pick something even smaller and lighter in order to to have reserve power. If you have a big 3/4 ton truck with a big engine you have more options, but the options do come with a price (more cost to purchase truck and it will burn more fuel).
Lot of reading can be found at "Tractor by Net" about baling with a compact tractor if you like to read. You will find both success stories and horror stories, but many of the horror stores stem from people not choosing their baler properly or planning to work around their tractors known weaknesses.
JD 14T used yet for small acerage on old home farm and some neighbors patches. Preferred tractors is a IHC 350D with live PTO but 1/2 the time neighbors using 8N Ford, brother used IHC H without live PTO or a late JD B and has used grandfathers old pre-war little B. Small odd shaped fields mean light windrows and sometimes clumps, don't rush and if you get a big clump just stop close by and use a pitchfork to feed it into baler. JD14T and 24T were built for the 2 cylinder JD Bs in mind- the heavy flywheel smooths out power pulses and helps lower HP engines continue baling when getting a bigger wad ingested. If you have horses, make the hay burners earn their keep by getting horse drawn mower and wagon to pick up bales. Local Amish sometimes use a 'power sulky' - horsedrawn cart with a small diesel running PTO to power balers or corn pickers. RN
I used my Jubilee for several years pulling a NH 66 PTO baler, and didn't have any trouble. Sometimes I pulled a wagon with it, too. Mine has the live PTO option, but even when I forgot and started out with the foot clutch it did OK. The biggest thing I would worry about it having a solid drawbar to pull from. The 3 point drawbar is too light, and the aftermarket swinging drawbar I had that bolted around the PTO shaft was made of soft metal and got loose after running the baler.
