OK so I will give you the run down and please let me know what your thoughts are.
Jugs are M5 Diesel jugs 4 5/8 bore and they are cut .030 oversized extra bolt holes have been tapped and plugged O-ring or Fire ring however you want to say it is cut in the heads.
Head were checked for cracks and .060 taken off of them
I am using a 1/8" base gasket to keep the pistons at or below the deck hight
Head gaskets are .060 copper head gaskets that have been anheiled to soften them
I have tryed everything to get it to seal up but I have had no luck at all the first few times I was doing moline spec on torq 115 and 135 using indian head gasket schlack on them leaked
tryed copper coat spray paint and 115/135 Leaked I have had it apart what feels like 35 times trying something diffrent each time last night I phoned a friend and he came and helped his idea 2 dry coats of silver paint and one wet one just before install torq to 185ft-lbs at startup it leaked instantly it pushes so much compresion into the radiator that it buldged the top tank. before the last install we used a straight edge and feeler gauges on the head and jugs and we couldnt get a .003 feeler gauge to go under the straight edge
I am looking for some help at this point I am ready to get a match and blow it up for good!!!
