Need help identifying MM
Dave LaRue
I have a 1969 Koehring PCM Skytrak 710 forklift that needs work. It has Minneapolis-Moline running gear. M-M package 78 gas. I'm trying to identify the engine. The block's casting # is 10A29242. I think I need M-M catalog R2139 for repairs. I can't find one. I have a manual for a 1970. That used a M-M package #80. 220A-4 gas. Can anyone tell me what I've got, or where to look? Thanks alot, Dave
According to my list pkg #78 used the prefix #s 347, described as "Jet Star 3 modified with Twin Disc Torque". No indication of years made or quantity made.
I'm thinking your package 78 has a torque converter.
The tag for your engine is (or was) on the right side centered low on the crankcase. should be 4 rivets there if its gone.
Is that casting number off one of the cylinder blocks, or off the crankcase?
Thanks alot guys. The casting # 10A29242 is on the crankcase, not one of the cylinder blocks. You probably knew that. Found the tag on the transmission. PKG 78 Ser# 34700245
