Riversedgefarms
Good morning i really need some help diagnosing a intermittent problem with my case 1594
When under load there are times it will drastically loose power and sound as if it's running out of fuel. But if you idle down and stop the machine it will regain rpm and idle fine. Sometimes after one of these episodes if you rev the engine to anything over 1300 rpm it will do the same thing. I'm really hoping I'm only dealing with a bad lift pump and not a failing injector pump. If anyone has experienced this any insight would be much appreciated.
