Need help with case 1594
Good morning i really need some help diagnosing a intermittent problem with my case 1594
When under load there are times it will drastically loose power and sound as if it's running out of fuel. But if you idle down and stop the machine it will regain rpm and idle fine. Sometimes after one of these episodes if you rev the engine to anything over 1300 rpm it will do the same thing. I'm really hoping I'm only dealing with a bad lift pump and not a failing injector pump. If anyone has experienced this any insight would be much appreciated.
Does this have a fuel filter pre lift pump? Fought similar problem on a Maxxum there was a tiny filter in pump inlet "plugged" it was about the size of the end of my little finger, had to cut band off pump to find it. thought I had some pictures must be in an old post. HTH Tom
Hi, I look at the fuel cap , on too tight, my. Dad made a nice tight gasket , sealed cap real good
learned to check that years ago on Case./ DB 995 ..
does your
1594 have a lift pump. ?
I have had the line from the saddle tank get filled up with congealed fuel deposits. Start at the tank or lift pump and work your way towards the problem to were you don't have fuel.
Thanks everyone for the information. Ended up removing the inlet off the lift pump and then re bled the fuel filters. And it seemed to fix the problem. Not sure what it did but I was able to run the machine for the rest of the day and feed cattle on Sunday afternoon with no issue.
