I have collected and worked on old tractors for many years and have not had to ask for any help on repair. I have helped others many times when asked to but now I am stuck on this one.
I have a 2006 Buick and need some information on the oil pressure and how the gauge works. I have an intermittent problem of an indication of low oil pressure. Is there a Buick service repair man that could give me some advice on what to look for. My email is open. Thanks much.
Is it really a low oil pressure problem? It might be a oil pressure sender problem. Never trust a electric gauge use a mechanical one to check it out. I have had many lie to me. A new sender might fix it.
I had a Plymouth that blinked the oil light idling.A friend who ran a garage said change the sender.I did and the blinking went away.I ve changed many that were leaking oil.
Eldo is right. the best thing to do is manually check the pressure. On an 06, the oil sending unit is not going to be hard wires to the cluster, it will be an input to the ecm and then sent to the cluster. Also chances are if your not hearing any kind of engine noise, then you probably do not have a low oil pressure problem.
