Need Mounting Brackets for a John Deere 260 Loader
I need mounting brackets for a John Deere 260 Loader. It needs to fit on a 4440. If you know where I can get them just contact me and I'll give you my email address.
I was all set to say Mother Deere didn't put 260 loaders on a Waterloo tractor of that size but......
I would go awful gentle with that combo of tractor and loader. A Mannheim or Dubuque utility tractor and up to the 2950 is lots for a 260.
How are you planning to connect the hydraulics?
(009001- )™BR>MOUNTING FRAMES - MID-MOUNT™BR>(009001- )
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 W38233 SCREW 2
2 11M7015 COTTER PIN 2 3.200 X 25 MM
3 24M7047 WASHER 2 13 X 24 X 2.500 MM
4 14M7184 NUT 2 M12
5 W37022 WEDGE 2
6 M45915 GRIP 2
7 W44422 HANDLE 2 (SUB FOR W31248)
8 34M7098 SPRING PIN 2 4 X 26 MM
9 W42632 BAR 2 (SUB FOR W30096)
10 AW23154 FRAME 1 (SUB AW25376, W33912, W35418 AND 11M7012) (SUB FOR AW22748) R.H.
AW25376 FRAME 1 R.H.
11 03M7209 BOLT 6 M16 X 60
12 W34119 STRAP 2
13 24M7241 WASHER 16 (SUB FOR W21684)
14 14M7291 FLANGE NUT 26 M16
15 AW24633 CROSSBAR 1
16 19M7397 CAP SCREW 12 M16 X 50
17 AW23155 FRAME 1 (SUB AW25377, W33912, W35418 AND 11M7012) (SUB FOR AW22749) L.H.
AW25377 FRAME 1 L.H.
18 W33912 PIN FASTENER 2
19 11M7012 COTTER PIN 2 3.200 X 16 MM
20 W35418 PIN FASTENER 2
21 19M7724 CAP SCREW 1 (A) M10 X 45
19M7875 CAP SCREW 1 (B) M10 X 70
22 19M7550 CAP SCREW 1 M10 X 35
23 W36838 SUPPORT 1 (B)
24 28H1524 SPACER 1 (B)
25 14M7296 FLANGE NUT 1 M10
26 14M7299 FLANGE NUT 1 M12
27 24M7047 WASHER 1 (A) 13 X 24 X 2.500 MM
28A 28H1892 BUSHING 1
28B 28H1892 BUSHING 1 (B)
28H1993 BUSHING 1
29 03M7292 BOLT 1 (A) M12 X 120
03M7227 BOLT 1 (B) M12 X 100
30 R34355 BUSHING 8 (SUB FOR W34603)
31 03M7212 BOLT 8 M16 X 80
32A W34341 BRACKET 1 (TRACTORS IN UNITED STATES AND CANADA)
32B W32734 BRACKET 1 (TRACTORS IN UNITED KINGDOM, FRANCE, GERMANY AND SWEDEN)
33 19H1768 CAP SCREW 4 3/4" X 2"
08H4812 BOLT 4 3/4" X 7", (SUB FOR 08H4220) (USED WITH CAST WEIGHT BRACKET)
34 W42934 LABEL 2 (SUB FOR W35405)
35 W42934 LABEL 2 (SUB FOR W35406)
.. AW24477 PACKAGE OF PARTS 1 (INCLUDES (4) R34355, (3) W21684, W34119, W37022, W38233, (3) 03M7209, (4) 03M7212, 11M7015, 14M7184, (7) 14M7291 AND 24M7047)
(A) FOR 4050, 4240, 4250, 4430 AND 4440 TRACTORS.
