hey guys today i wasnt busy with anything else so i decided to install the roller rockers i got from murphys on my farmall M that are 1.7 and 1.9 ratio, the M has a M block with 450 pistons and sleeves (281) a brand new reproduction LP head that (isnt) ported or polised. lp manifold from stiener tractor parts, a new 450 cam from stiener tractor parts also, a carb bowl that is off of like a 301 combine engine? has a bigger metering stem then a regular M?it has a venturie that someone took to a lathe at one time and its kinda between a #27 and #29 venturie.. petronix electronic ignition, runs on 110 octane other wise it pings and farts and bangs on just 87 or 89 or 93, and runs very very nice on 110, its got around 195 -200 psi cylinder pressure. it runs around 2200 rpm and it gets 61 horse on the dyno before the roller rockers? i installed the rockers today and ran it on the dyno and it got pretty much the same horse power at 540 pto?! i backed the full load screw out on the carb 1 turn and got 1 more horse?! backed it out one more turn and got the same results? and i took the bowl off and the full load screw is about an 1/8 away from the jet in the bowl and well im thinking the tractor could take more fuel but is being restricted and the tractor doesnt smoke black like its running lean ?!?! the tractor runs very nice and lugs down good and pulls good other then it does smoke white just a bit when you start it but goes away right away! i took another bowl off of an M that had the main jet drilled out about 5 drill bit sizes bigger and with the holes in the mettering stem about the same size and tried that but seemed to be way to much fuel as is i had the screw in pretty much until it would seat up against the main jet and would open the tractor up and would die ?! so im stumped? im thinking a little bigger jet then what on the tractor for more fuel but not over board?! and i set the rockers at .020 thousands cold if that makes any difference? im thinking theres more power there but is hiding somehwere?!?! help!!
