Need some advice
aarolar
The hydraulic top cover is busted on my TO-35 and I am going to attempt to fix it and am looking for some advice. I weld for a living mostly tigging small machine parts and some FCAW welding on larger parts. I have done a small amount of brazing for the local paper mill on some rather large (1000lb ish) bearing housings and so far I have not heard back from them so it must have held. :lol: I have also done some silicon bronze work with the tig rig on smaller cast parts and felt like I had much better control over the puddle mostly because I do alot more tigging than anything else. So my question is what is the best method to use on this cover?
When I did the large bearing housing we had two people with rosebuds on it keeping the temp up while I brazed it then we wrapped it in fire blankets overnight to let it cool slowly. This housing would be easy enough to do at home and use my wifes oven :shock: to cool it down. Cast iron repair is something I really want to learn more about because it seems to be more like a black art than anything else. I had an old guy who knew all the old ways like brazing silver solder and SiBronze welding but he died unexpectedly and now I am on my own I really miss that old man something terrible. :(
See you lost me already :P I dont have any experience using cast rods although we do have them at work. Why would you go for cast rods vs brazing and how often to peen and with what, a chipping hammer or the ball end of a ball/peen hammer?
I was thinking it might be good to weld it bolted onto its base . They way you have it cleaned up it looks as if you could run a bead on the outside enough to seal it up without having to do any machining of the mating surface. Nice prep work.
Aside of the welding process you might want to check
over at the Ford Forums. Seems to me that there is
something in the lift that goes bad or breaks that
causes that??
I would go and get a replacement from the salvage yard. Probably broken by the lift cylinder out of adjustment and pushing on the housing. Lots of pressure on that cover.
Just out of curosity it looks like you ground the crack with a grinder which is ok to start with. You prep area with grinder but finish everywhere you are going to weld with a file. Reason is cast iron has large grains of carbon in it that "smears" when ground and contaminates the weld.Where as the file cuts them off clean. This comes from the old timers I worked with in the power plants. I did some brazing of cast iron but have more experiance machining it. Im sure I will be told I am full of it.Is it cast iron or cast steel?
My. dad, a welder taught me to braze. I assisted him repair a Cub engine that had been pulled apart. He ground just as you have done, tacked each end and middle, then flipped over and ground and tacked the opposite side. Then completed one side, ground out the tacks from the other side and brazed the other side. I usually put the parts I'm brazing on the propane fish cooker and preheat and braze with it on low heat. I have repaired quite a few items by brazing.
That is an interesting project. "It's going to
pull 7 ways from sunday", as my friend that taught
me to weld would say. lol I would use ni99 rod as
well. Also when I do something like that I try to
weld the inside first so it pulls everything tight
and that will aslo help keep it straight. You may
want to have it milled flat before you try to bolt
it down. I think you will have a hard time keeping
it straight enough to not crack when you put it
back on. Other than that I think it should work
ok. Is there a reason you don't want to get a
replacement?
I was just looking up the specs on some Ni rod today. I've got a bunch of Harris NLW 59 rod- That one they say to preheat to 400 and then let cool slowly once done welding. The other rod they have is NLW 99, which is what everyone is recomending. That one says preheat is still good, especially on big castings, but not life or death from what I read.
How did it break? Certainly not impossible to weld and probably something I would try to tackle.
How would I do it? Carefully. I really don't know how I'd approach it though, but if you can clamp it flat it would probably help. Would probably still need to dust the bottom side once done to make sure you don't put any more stress on it.
Donovan from Wisconsin
That is a good job for O/A cast iron welding,
many times arc weld on something like that will
come back to haunt you.Brazing would be much
better than arc ,and o/a cast iron would be
better yet , and stronger as it becomes part of
the work and not bonded to it.
Items needed -- pile of fire brick,1 or 2
large propane torches ,# 4 or 5 welding torch,
can of good welding flux , temp gun to get the
temp right to weld and to normalize when done,
ceramic fiber to cover while heating and cooling.
Need 1000 to 1200 deg preheat to weld and 1500
to normalize ( for 15 minutes ) when done.Temp
drop from 1500 to 1200 should take at least 1/2
hour so as not to chill and make it hard and
brittle.
Below is a photo of the brick oven to heat
the engine. Also the link below will show
the cylinder before and after the weld.
george
<p align="center">
oven with 2 propane burners to heat
casting to 1200 deg F to weld</p>
welding engine
I think it looks like a pretty nice casting...
Do you know what kind of iron it is?
A simple spark test can help you, theres even a chance its cast
steel... Malleable iron isnt hard to stick weld, but grey and white
can be...
video1
<object width="560" height="315"><param name="movie" value="http://www.youtube.com/v/cFf_x97vcQ0?hl=en_US&version=3"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/cFf_x97vcQ0?hl=en_US&version=3" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
I could repair this piece and when I got finished you would have to look very hard to tell if it had ever been broken,but you would not like the price, and I would not arc weld it. To repair cast is very expensive, any way that you do it. Ni-rod is in excess of $40.00 a pound. Brazing rod isn't cheap either and acet and oxygen are out the roof. I'd opt for a used lift cover, unless you just want to try your luck at repairing cast, but I'd have a replacement lined up before I started, it may not turn out the way you had hoped.
Why not simply replace it.
Used replacement lift covers are readily available and modestly priced.
Dean
(quoted from post at 08:23:11 02/27/13) Why not simply replace it.
Dean
Y'all are seriously missing the point, this isn't about saving money this is about advancement of my knowledge and skills. I weld and fabricate professionally and the more skills I have the more desirable I become in the labor pool. Besides the fact the rods and gas are free so what have I got to loose?
Braze it unless you want to get into what george is doing...
I often arc weld smaller pieces with Sodel 35 rod and it works fine but something like that will crack all to hell when it cools if you try to arc weld it.
Rod
(quoted from post at 09:54:44 02/27/13) Braze it unless you want to get into what george is doing...
Rod
I would love to apprentice under somone like George, I really like learning to do things most people consider impossible.
Not trying to scare anyone off.Most people just don't realize how much welding supplys have gone up in the last year or so. I just think you could probably find a good used one for less money.Some things it pays to fix and some doesn't
I've been doing this suff for a lifetime. Going to be retiring before too long.
That's the best kind of jobs to do. Please post
update and pics of what you decide to do. I'll look
forward to it.
Agree... I bought a sleeve of brass the other day that cost over 90 bucks. At 300 bucks I think you're working cheap.
Rod
Are you going to machine the cover flat afterwards? If not you will probably have leaks.
I like welding odd things like that or brazing them. But picking your battles is important too.
I know you want to learn but to repair that part when a replacement is so readily available is just plain silly and a waste of resources.
