hey fellas! im in need of some advice on what to do! got my fisrt pull in a week and a half! got alot of guys counting on me bringing my M that im building! well sunday i got the motor in the tractor(Its a M block bored with 450 c281 sleeves in it with domed pistons from tisco i beleive, 400 crankshaft, stock goveneor, petronix electronic ignition, a brand spankin new lp head and manifold, the top of a IHC M carb with a ih bowl off of a 301 combine engine ibelieve with the big metering stem, a #35 venturie. someone on here told me i needed to run higher octane gas. well i got antsey this sunday and decided to get the motor in since it has been sitting on the stand done and ready to go and i got it in just put 87 pump gas in the tank to run it to get warm and retorqued everything and checked valve clearence and well it proably hasnt had a good 45 mn of run time yet but i did a compresion test and it has around 130 psi. it had a slight puff of black smoke when i opened the throttle up on it like it needed more fuel and was kinda pingy ? im in need of knowing what i should run for fuel since it doesnt have quite as much compresion as i thought, what spark plugs i should run? and what i should do for my carb problems? need some serious help guys cuz that pull is creepin up fast!
