Need to rig up something...
Anonymous-0
Some ijit ran down a sign I made out of some farm junk, and I need to make a patch, does anyone know what the ID of a 4" schedule 40 coupler is? I need about 4-1/2" to 4-5/8" ID, to slip over the broken ends of the signpost, and attach all together with set screws. If it's a little tight, I can turn the ID to what I need, if it has thick enough side walls. Any other pipe out there, with a 4-1/2" ID??
Thanks for the offer, George. I think I can find the coupler local. Have you ever seen a tobacco prize screw? That is what I'm using as a signpost. Can't weld it at the end of the driveway, AND it's cast iron! Whoever did it, will be in for a surprise, if they try it again, I have some sharp improvements ready for them!
shcedule 40 plastic ,4.5 inches od with a wall thickness of .237"
steel pipe, has the same od, but the wall thickness varies by the wt of pipe . std wt black/galv pipe is the same as schedule 40 pvc
IF you use a threaded steel/sch 40pvc threaded coupling,turning the threads out should make a slip coupling. if this is what you need,and its strong enough, a sch 40 glue coupling should slide over either snuggly. problem may be putting your set screws in a pvc coupling. even though its very easy to tap, threads would strip easily. in that case,or if its a problem, a schedule 80 pvc slip coupling would have thicker sidewalls but the same id,IF you could find one of course. most normal pvc couplings will have a stop inside, if thats a problem look for whats known as a slip/repair coupling its exactly the same without the stop. hope this helps!
A regular 4" pipe coupling should be about perfect for you, to buy pipe to fit would be very expensive.
I think I got 'er licked. Stopped by my friend, the starter and generator rebuilder, gonna try a generator housing. Gotta take the core apart, to see if she'll fit! I did hammer in 2 half t-posts, right into the wheel tracks, where the SOB backed up the bank, to KO the sign post. I cut them at a 45 degree angle, so they WILL flatten tires!
