Anonymous-0
My MH 444 hasn't been started for 6 months. I get an initial pop and then it just cranks. I removed the battery to charge it. When I replaced it, I hooked it up with a negative ground because every vehicle I have owned has had a negative ground. When I pull the wire out of the center of the distributor cap and hold it near the engine block and press the start button, I get a yellowish spark, not the fat, bluish-white spark that Jerry/MT says is necessary.
I read in my owner's manual that the tractor came from the factory with a 12V generator with positive ground. A previous owner replaced the generator with an alternator, so I'm thinking that that required a polarity change. Is there a sure-fire way to determine whether an engine should have a negative or positive ground?
