new battery box on 730
old red guy
completeing resto on 730, when I the put on new battery box(which was orderd as the one for a 730)there is a piece of 1-1/2 strap on the lower right side that goes out about inch or so and down a couple of inches give or take and then back in to the box with 1/2 hole in it on the vertical corresponding with same size hole in the box. it is in the way of my 3-point hitch control lever operating correctly. I could not find it in the parts book to determine its use. I can shimm the contol levers holding device to clear the 3-point lever if it is important or if not cut it off the b. box, but then I would have redo the b. box. ANY SUGGESTIONS - PLEASE
The bracket is for the PTO lever on the early number JD's.
There are several batt boxes for 730's. Depends on wheather it is gas, diesel, and it is pony or elec start.
i got a new box for my 720 it had this bracket on it so i took angle ginder to it works fine now and you realy need to look close to see ware was
most if not all battery boxs are "fit all-fit none" style ...I got the same box for my 720...just take a grinder & razor wheel & cut it off..grind smooth ...paint
Somebody out there actually makes the correct boxes instead of forcing the "one size fits all" design. I cannot think of where I saw them but they are out there.
When we stop paying for garbage and stuff that is not made correctly, they will eventually stop selling it because they cannot make their huge profits on it.
There are 3 correct boxes for the 730 depending on what you have, but the one you got is for 50-70 as you were told.Even if you cut off the bracket it might not be right since I didnt see where you said what 730 you have. The gas, diesel, and pony start each have there own size box,so you need to specify. Good luck
