I have a model #1034 with some issues. I just purchased this spring so am in the learning process. I think my problems are hydraulic. Two big problems: #1: the pickup chute hydraulic motor is hard to keep running. When engaging the drive from the tractor, there seems to be a "sweet spot" you have to achieve with the lever to get it running. It is very hard to find this position. If I push the lever forward too far the motor stops and something squeals. A mechanic from Roeder Imp. in Kansas told me the valve which operates the load chute is missing a clip behind the spring on the valve. Wasn"t the problem. Had it all apart and nothing wrong. So when I try to load bales most of the time I can"t get the pickup chain to move. Problem #2: Table #1 seems to slow down in its delivery of the 3 bales onto table 2. The motion seems to actually slow down. The same thing happens on table #2 when it loads the 15 bales onto the main rack. It sometimes seems in slow motion. Then it doesn"t achieve its full up position and starts to squeal. When this happens I have to run back and manually move the rolling rack back a bit to get table 2 to finish its motion up and then return down.
I have had the main pump and relief valve checked by a reputable local business. They said everything checks out. I drained and replaced the
hydraulic oil with 20 weight hydraulic oil. I purchased a hydraulic guage and checked primary pressure. It is 2000 psi. Secondary pressure is 1900 - 2000 psi BUT before I had it checked out, I did notice a fluctuation in the pressure when I deadheaded the rolling rack. I could not get it to stay up to 2000. But they said it checked out fine. After I reinstalled after the checkout, it seemed to stay up in pressure.
Anyway, I am getting very frustrated.
