The loader jerks really Bad when the oil is hot . I have replaced the pump, loader control valve, relief valve, change filter and oil ,replaced all suction hoses on suction side of pump ,changed the quick couplings and switched the hoses on the lift and replaced the cylinder packing . Installed a flow meter on the lift hose, I have 5.5 gallon a minute at idle and it will drop to around 3.5 when it jerks and go back to 5,5 till it jerks again and pressure stays around 500 when lifting . Pump puts about 11 gallon at 1500 rpm’s . When the oil is cold it does not jerk the warmer it gets the worst the jerking. I have talked to the dealers around here they were no help. Any recommendations you have will be very helpful.
