I have a NI No 18 spreader and one of the tires is done. The tire size it has on it is a 7.5-20. I have looked around but finding these tires in an R1 tread configuration is hard. When I do find one they seem crazy expensive, haven't found any used just new. I was quoted ~$275 locally for one installed on my rim. Is there another size option that would work? Or maybe a different rim/tire combination that could be substituted? One problem is that only 1 tire really needs replaced. The rims are probably the stock rims and have seen better days (but usable). Any suggestions would be great.
Another question is that I have had some trouble with the tension sprocket for the paddle wheels. The chain ate the one that was on it, I got a new one, it seemed to be fine and then the chain ate it too (not sure how bad it is in the field somewhere behind my house). Any ideas on another option that would allow the chain to travel/move some (side to side) without eating sprockets? I toyed with the idea to put a wide plastic wheel (like they use on zero turn mower decks which would allow movement but have not tried anything yet (Tire is done, its not moving anyway). I realize that everything should be tight and probably shouldn"t be any movement but its old and if I had a lot of money to put into it then I would have bought a newer one.
