Had a front tire on a Mahindra 8560 give up while finishing late planting. It had about 50% tread same as the other front and rears.
The tractor is used 100+ hrs yearly with about 1/2 doing field work and rest using FEL, Forks and Brush Bucket. It does get used to hydraulic limit of FEL occasionally.
Tire size is 12.4x24 Titan.
http://www.tractordata.com/farm-tractors/007/1/7/7174-mahindra-8560-photos.html
Since it is a MFWD, could running a 100% tread across from a 50% cause issues when it is engaged? What about using without MFWD engaged?
Should I replace just the one or both fronts?
Has anyone replaced the one and had issues due to rolling circumference?
What say you??
What say you??
