kneedeep
Had a front tire on a Mahindra 8560 give up while finishing late planting. It had about 50% tread same as the other front and rears.
The tractor is used 100+ hrs yearly with about 1/2 doing field work and rest using FEL, Forks and Brush Bucket. It does get used to hydraulic limit of FEL occasionally.
Tire size is 12.4x24 Titan.
http://www.tractordata.com/farm-tractors/007/1/7/7174-mahindra-8560-photos.html
Since it is a MFWD, could running a 100% tread across from a 50% cause issues when it is engaged? What about using without MFWD engaged?
Should I replace just the one or both fronts?
Has anyone replaced the one and had issues due to rolling circumference?
What say you??
Unless I were using the FWA on pavement I wouldn't worry about it. It is designed to be able to slip on turns and differing traction situations, so a little extra slipping at work speeds wouldn't generate enough heat to worry about.
In an ideal world, I would say to replace both, but tires are expensive and I expect that with all the
loader work you are doing that you are also doing a lot of tight turning, so the ratio between front and
rear, and side to side is off a lot anyway, plus it sounds like you are mostly working in loose dirt and not
doing a lot of running on hard surfaces, so my pocket book would rule and I would replace the bad tire
only.--------Loren
Tractor tires in picture look like a lot more than 50% tread left.
One of my MFWD tractors has a limited slip front differential. You might want to check on that. But from what I see in the picture, no need to buy two tires.
if using fel a lot you don't want to blow a tire when at full height with a full bucket, it's a judgement call.
your call your tractor and your the one that can see the condition of tires. the circumference makes no difference as that is what the differential is for. wont be much difference any how. only time to worry about circumference is on dual wheels.
