grandpa Love
Bought a small winch at harbor freight on black friday. Does great pulling cubs up on the trailer, but struggled with the Farmall A, with wheel weights. Wife says today is the day to upgrade. Any opinions on harbor freight vs tractor supply?
very happy with my HF 12,500 #. the wired remote shorted out a couple of years ago and found they had an adaptor for the wireless. good made better. winched a Jeep Cherokee with locked rear brakes and a mid '70's Eldorado onto my gooseneck with no problem. tractors with at least rims are very easy
Harbor Freight would be my first choice, not for everything but they have a good reputation on their hoists and winches.
It may be an individual store management issue, but the Tractor Supply here is my provider of last resort. Nine out of 10 times I leave empty handed.
They never have what they are supposed to have and the employees are clueless. Show them a picture from their own website, and still don't know what it is, so no, they don't have it.
I had a HF Badlands 2500 50 buck winch with wireless that worked for a number of years. Kept breaking the cable dragging it over stuff but the winch always held. Bot a TSC brand 3500 winch on sale for 79 bux and put it on. Used the same wiring and wireless controller from the HF one since it came with the wired controller. I see TSC sells the wiring kit for 50 bux so I figure the winch must be worth 29 bux. When I bot the bale mover to put on the back of my pickup, it came with either 2 ga or 4 ga wire double strand that I ran from the solenoid and along the frame rail and back up to the bed so it runs the winch too. That stuff is expensive on its own.
Unless you are planning on getting more heavier vehicles and equipment, you could just get a snatch block to double the strength of the current winch, but, you do have Grandmas' approval for a new bigger winch, and everyone knows, bigger is better.:>)
Look on ebay I bought a 12,000 winch off ebay about the same as the HF winch for $299 a few years ago has done good for me and still going,I usually use a snatch block to slow it down some,less strain on the winch etc.Also take about half the cable off the spool it'll give it more power and keep the cable from binding up.
very true about being out of product. especially hardware and propane. and this was long before the current struggles
I have one on my trailer, about 3 years old, it's a 3500lb rating and I have a snatch block as well. I've pulled several dead tractors on my trailer with it from Cubs to a Massey 50 with no problems. And I run it off a lawnmower battery because it takes up less space in the tool box.
I'll try and get you a picture of my winch and snatch block set up on my truck to give you an idea of what it looks like and how it is set up. Winch is rated for 3500lbs but with the snatch block will pull almost 7000lbs. That was not enough to load the IH584 I have but I was also way over loaded when I haul it home
I have a 12000# Harbor Freight winch and it had no trouble loading this 10000 930 Case tractor. I did use a snatch block to save on the winch. Ran the cable to the snatch block pulley on the tractor and hooked it to the front of the trailer...never slowed a bit. Winch is on the one ton truck so I can use a couple different trailers.
John, I haven't seen the ride route this year, but hopefully it won't be in my area....would not be very scenic, it's a disaster. The Willow City to the Cherry Mountain area took a really hard hit! Damage to every tree on my place, looks like a tornado came thru. The next 2 land owners will be picking up debris. Wind has been crazy this past week, blew the skylights off one barn.
